My manual transmission seeps a bit of oil. I haven't taken the time to diagnose the source but meanwhile the dipstick tells me she could use some topping up. Long ago I did this by drizzling ATF through a plastic tube threaded to the dipstick hole. An awkward operation. However, I seem to recall, as per this forum, that there is a more accessible place for filling the tranny. Can anyone fill me in?
Moderator
theres a big plug bolt on the top front of the gearbox, just infront of the slave cylinder i believe..
Yep and depending on year either an allen head plug about less than 12mm (earlier models) or a 17mm hex head plug with copper crush washer.
Use a long flex tube sort of like one for filling A/T domestic models through dip stick tube or even smaller.
Awkward is having to take the left wheel out on the ZX and pouring the oil through a little hole in the arch liner.
My brother had a seeping oil issue a few years ago (on the diesel ZX) and fixed it with an additive I can't remember the name. I heard of one of those products from Scotty Kilmer, you might want to give it a try.
Moderator
Listen guys you don't have to do that. Located allen head or hex head plug near clutch arm pivot point in front of tranny and fill it there. If 94-95 model there is a switch in the fill hole see pix in post 6 in this thread for location of allen/hex/sender fill port:
http://www.alfabb.com/bb/forums/164-168-1991-1995/46341-gearbox-differential-fluid-change.html
