Borrowing the photo from a fellow Berlina owner - anyone have an approach that works for the corrosion on the trim that can be seen here and is common on long term stored cars?
Corrosion
Hello tdskip:
I've had good luck with #0000 steel wool (only #0000!!) on chrome and other shiny bits. No scratches.
Looks like your corrosion may be under the clear coat, however, which is obviously a different situation. Those pits may be permanent.
Best wishes.
agree - except I dip the finest grade steel wool into some chrome/alloy polish to help it along.
You really don't want to use anything abrasive on chrome. Chrome is a very thin layer...if you scratch it you're hosed. You do not actually abrasively polish chrome, you just clean it.
I've had quite good results with Nevr-Dull cotton wadding polish. It's a lot of work, but it'll take off a lot of crap and not damage the chrome. When I need to get more aggressive (or my hands get tired) I've used a rotary polisher with a microfiber bonnet and a polish specifically designed for chrome (I've been using Mother's).
If the chrome is pitted or worn through, not much you can do besides replate.
Tom:
Generally I'd agree with your thoughts on using anything abrasive, but #0000 steel wool is like magic! Accidentally used some #00 on my Nighthawk pipes once and scratched one as soon as I touched it :(.
Nevr-Dull sounds like a good option and I've also used the Mothers (no apostrophe?) Mag and Aluminum polish (by their own admission, "perfect for all metals") you mentioned.
Got a tube of Wenol Metal Politur in the garage that I've forgotten where it came from, and it's a great product as well. Instructions in German, English and french.
If you are asking about the trim around the glass it's not chrome, it's stainless and can be repolished. It's tough stuff though and takes some work - best done off the car on a polishing wheel with appropriate grades of rouge.
The louvered vent could be aluminum, which could be sanded and polished but it's more likely chrome and would have to be either replaced or re-plated. When chrome plating gets pitted it's done for.
