1 - 13 of 13 Posts
Hi All,
Can someone tell me how tight the top ball joint nut should be. it has a spring that keeps the top cup in tension. the giulietta workshop has no information.
cheers Ian
1689917
The ball joint is 3 piece, plus has a spring under the nut that puts tension on the top cup, so the squeeze pressure on the ball is controlled by the nut. not sure how tight tight enough is,
1689922
You pretty much tighten it snug with a crescent wrench or equal...to lock it snug.. then you back it off enough to insert the retaining ring leg that goes on by matching the slits on the nut and A-arm perfectly in line with each other to receive the spring retainer.. It is sort of like the procedure to seat wheel bearings.
Uncle D&T is spot on as usual !!
Discussion Starter · #7 ·
Thanks, that was the way i was approaching it, thanks all for the feedback.
Is it the picture or is it me....?? the stem of the upper ball is the weak link. When people drive with a broken limit cable the stem will bend...very common to find this. I have a collection of them.
Discussion Starter · #9 ·
no its shadowing in the picture, the other one is bent and i'm finding it hard to find a good quality replacement.
Also what grease should i use , i have some of the modern red grease but something about it I don't like
cheers Ian
I use waterproof wheel bearing grease, the stuff for boat trailer bearings. My reasoning is that it's tough enough for wheel bearings and if I do get caught in the rain at least it will resist washing out or emulsifying in the wet
Ciao
Greig
When the pain comes in my elbow, its tight enough.
Reactions: ITALCAROZ
Discussion Starter · #13 ·
1 - 13 of 13 Posts
