shocks-
It may vary but here's what Koni says- if you notice the od of the bushings is smaller than that of the washers. What they say is to squish the bushing down till it matches the washer when looking down the sides. And/or if you use the double nut set-up there should be just enough threads with none showing with the second nut seated. Fred.
