1 - 2 of 2 Posts
I need to replace the dash in my 68 Spider as the PO created a big mess installing a radio. How long a job is it to take the dash out? I already have the steering wheel off if that is part of the equation.
Not long at all. First mark and disconnect all wires including the speedo and rpm cables- both should unscrew by hand. Next unscrew two screws that attach the heater adjustment assembly to the bottom of the dash. Next undo two bolts, one each end of the dash. Undo two screws holding the choke/hand throttle assembly. Next, unscrew three connectors (should be wing nuts) under the dash which connect the top to the car. There is one behind the RPM counter, one in the centre rear of the dash and one behind the glove box. The whole thing should then lift out. Replacement is the reverse, but getting the dash top to stay in the right place is a fiddle.
John
1 - 2 of 2 Posts
