We had an extremely hot summer here in Chattanooga this year which prompted me to fix my A/C. I converted to R134 and it gets cold. You have to spend some time doing a search on this forum to get a firm grasp on the obstacles to overcome on the 164, but it can have cold A/C using R12 or R134. You must make sure the trap door that shuts off the heat from the heater core works and you really need to install a manual heater core shut-off in the heater hoses (otherwise hot coolant flows through the core at all times) under the hood to completely stop the flow of heat to the core otherwise you are competing with that heat in the climate control box. Make sure the climate control steppers function correctly and then make sure your A/C system is properly charged with Freon (whichever one you chose) and the rest should be serviced as any other A/C system.
Charles
Charles
