I've never seen one where the terminals go up. Are you sure that you have the right holes? No offense intended with that question.
The proper way to close the hood on a SPIDER is to drop it from 8 to 9.5inches from the opening. It all depends how much featherfill is under the surface of the finish coat. These are not Porsches. Pushing will deform your hood. ... and BTW balls are good. Test fitting if in doubt, should be done with Playdough and the latch and safety latch removed from the hood.. Keep firing .. I'm hot!No offense taken..I tested fitted the regulator tonight and got the balls to close the hood hard and it fit!
Dave thanks, as you know my car was all apart when I got it so trying to figure the schematics of where and how everything goes. Is the battle ship grey car original wiring? I have a new wiring harness from Lionel.
Thanks.
