I have a question on suspension settings. When I got my S4 I found the stock suspension was impossibly stiff, so much so that the car would oversteer at the drop of a hat. In fact it was down right dangerous. Now I have a series of mid engine cars (two Ferraris at present) and I know a thing or two about how a car should handle, the Alfa felt horrible.
I talked with the guys at Alfaholics here in the UK who are very highly recommended and their opinion was that the S4 (at least the european version) was built with sucicidal handling so they developed a suspension kit of new springs, Konis, and a new front roll bar. They suggest removing the rear roll bar entirely and fitting a thicker front roll bar. New bushes as well all around. Because of the cost of the kit I have fit just the rear springs and rear Konis and it has made a big difference. The car still feels much to "stiff" and the scuttle shake is unreal.....I plan to eventually fit the front springs/Konis/rollbar (if I keep the car) but it leads me to wondering...
Is this a problem the US cars have? I realise that the USA has very few places with true handling roads compared to England where there is a roundabout every 5 feet, but do the USA cars understeer or oversteer? Even with the rear handling kit fitted my Alfa is VERY eager to turn in and many S4 owners over here have had their cars rear come around on a wet roundabout...
I haven't seen to many threads on suspension setups to improve the stock settings. I dont want to "low ride" the car or fit non stock wheels but the handling is a huge disappointment for an itailian car....even my Triumph Spitfire felt better in the corners. I am using and will use Koni Sports (yellow) which are adjustable....should they be set harder or softer? I am looking for neutral handling or slight understeer; as it stands the car is just to eager to turn in making it a bit iffy on our often rough and wet roads.....
I do know all the tricks for understeer/oversteer with tyre pressures ect; what I am wondering is where to start with the overall setup....has anyone else already fitted the full Alfaholics handling kit and will it make the car handle better, safer, and with less scuttle shake (as they claim)....
Thanks for your advice
Britt
Britt
