1 - 5 of 5 Posts
just thought- our calipers dont have any "sliding bolts" like Ive seen on other cars. These sliding caluipers are what allow the pads to retract away from the disc (right?).
So then how do our brake pads retract away from the disc after we press brake then drive off? Just wondering cuz otherwise, discs should become worn prematurely, right?
Still rebuilding our caliper and just thought- our calipers dont have any "sliding bolts with booties" like Ive seen on other cars. These sliding caluipers are what allow the pads to retract away from the disc (right?).
That's a floating caliper. Usually they have only one piston on one side: the caliper moves on a sliding bolt so that both pads make equal contact.
Spider fronts have a fixed caliper: there is a piston on each side, and both pads move independently towards the disk so the caliper doesn't have to move.
In both cases the retraction is the same. Once you remove the pressure on the pads, the pads (or pads & caliper) move such that they're no longer exerting any force on the disk. They remain just barely kissing the disk, but this doesn't cause any significant wear.
Correct. Be glad our Alfas have this style. The double piston concept is a better, and more expensive, design. Sliding caliper brakes are used as a cost reduction since there is only one piston per caliper instead of two. This is much less effective if the caliper doesn't slide when the brakes are applied. When this happens, you effectively only have one of the two brake pads in the caliper pushing on the disc. My motorhome has disc brakes, but they are sliding caliper design, and the sliders need periodic maintenance to function properly.
1 - 5 of 5 Posts
