So my window is rolling up only half way because the glass panel somehow moved. I’ve got all the screws and bits and pieces off but can’t seem to figure out how to remove the top chrome piece.
I’m a pretty clumsy guy so don’t want to remove it without know the correct way, any help?
Discussion Starter #2
Update: so found out I don’t need to remove the trim to remove the door panel, I just slide the panel downwards from the trim.
1603734
If you did want to remove the trim you have to take the panel off anyway to access the 3 small phillips head screws that hold it in place. Then you just push it upwards to remove it, taking care not to scratch the chrome on the 1/4 window frame ( i put some very thin plastic sheet between frame and trim to stop scratches ).
