My door handles are worn and hard to open. I have a fairly new set (115), but I would need to use the old door lock cylinders since I don't have the key for the new set. I can't find any information on how to disassemble the. Any ideas?
--TIA
Bruce Sharer
Raleigh, NC
1972 GTV
gtv door lock cylinder
Its pretty easy, once you take a closer look you'll figure it out. There's a pin on the back of the cylinder that needs to be removed, pay attention to how much it prodrudes and from which end. Keep key in as you remove it from the handle and take pictures as you disassemble it. Grooves on the handle are opposite between left and right side. Try searching, there are couple threads on door locks.
