My Spider came to me with an off/on switch as part of the battery hold down frame.
It is also an effective immobilizer.
What about the one already mounted in the pod ? Are these typically accurate or do they work as well as out tachs and speedometers ?A Voltmeter gauge installed in the car is a very important informative and diagnostic tool IMO![]()
and still have a Voltmeter installedthe way tom said is right, to check for current draw, use an ampmeter with the engine off. pull the fuses one at a time till you find the circuit thats bad.
current drawn all the time is probably an alarm oe clock. some radios pull a little current to keep memories.
cliff
I do not utilize a tender. My car gets used every week and does not sit for more than 5 days without being run. No Optima for me - I purchased an Interstate battery (I think a size 24) which I am told are decent batteries.My car didn't have a Voltmeter only the dreadedidiot discharge light. With the Autometer gauge, my system is putting out 13 + volts while the
above mentioned light faintly glows. What kind of battery did you get the krapped out in 2 months? I trust you always have a Battery Tender connected -right
. You didn't get one of those Red top Optimas did ya' cause if you did let it discharge, its toast.
10-4The S4 already has a voltmeter built in. He is asking about finding a drain, Lowmileage. Two different subjects.
I use a Tender all the time. It's said to extend battery life 2-3X. Plus I then know my batteries don't discharge and will start the car all the time. I think it is a good idea for you to get one - they are only about 30 bucks. You hook up a "pigtail" and it's very easy to attach/detach. Plus, you need a battery disconnect switch. I also have a CD with a clock in it - I wish it didn't have the clock. I turn the battery disconnect switch off when the car is garaged. Something else you should have if you don't already IMO.I do not utilize a tender. My car gets used every week and does not sit for more than 5 days without being run. No Optima for me - I purchased an Interstate battery (I think a size 24) which I am told are decent batteries.
I'm wondering if the new Alpine I had installed a few months back has anything to do with this? I realiuze that there is a constant draw to keep the memory in--tact. Sort of like the Borg digital clock I have.
I'll certainly look into this over thew weekend. If I do the battery disconnect thing then I'll have to deal with resetting the clock and radio pre-sets. Sounds like a PIA to me. Where can I pick up the pig tails you speak of? Autopart store ? Mycar is garaged and covered so I am trying to figure how to keep her both covered and allow for a trickle charger at the same time.I use a Tender all the time. It's said to extend battery life 2-3X. Plus I then know my batteries don't discharge and will start the car all the time. I think it is a good idea for you to get one - they are only about 30 bucks. You hook up a "pigtail" and it's very easy to attach/detach. Plus, you need a battery disconnect switch. I also have a CD with a clock in it - I wish it didn't have the clock. I turn the battery disconnect switch off when the car is garaged. Something else you should have if you don't already IMO.
