1 - 18 of 18 Posts
Its only the spigot bush, fit a new one and all will be fine. Looks like someone has damaged it when knocking it in last time ?
Steve
If you have a steel shaft that is a close fit in the bushing do the following: pump a good amount of grease into the bushing. Push the shaft into the bushing then drive it in with a big hammer. The grease will get behind the bushing and force it out. I have a tool that is gentler. It screws into the open end of the bush and it has a grease nipple you pump grease in and the bushing comes out. The thread is tapered and it is a universal tool that you should be able to find at an online tool store. I can lend you mine if you cannot find one.
I would clean the internal threads for the flywheel bolts. If too much debris gets in there the torque readings will not be accurate. Good luck
If you have a steel shaft that is a close fit in the bushing...
I've done the same with a wooden dowel.
Agree. Use a thread chaser or re-threading tap, not a cutting tap. A thread chaser/re-threader is designed to clean & straighten existing threads without cutting any metal. A cutting tap might inadvertantly remove some metal.
You can also use a wooden dowel which is easy to turn down to the right diameter on a bench grinder or file down.
I have never installed one before, but it may be a good idea to keep the new bushing in the freezer overnight before installation. It is probably an interference (or near) fit. Shrinking the new bushing will allow for an easier install.
Discussion Starter #13
And that's what I'll also ask for. Thanks!
Rather than buy that tap you will only use once (hopefully) you can clean the threads with a sharp O ring pick. Generally the old red locktite is what needs to be removed.
too hard
It is possible the internal threads of the crankshaft are hardened and using a regular thread cutting tap will not damage them. I do not have an answer for this, but if I recall my days at the Chevy plant, all the machining was completed and then the cranks went in the furnace for surface hardening. That was 40+ years ago
They make a thread-in pilot bushing remover, tighten up on its pipe thread til it seals, pump full of grease on the provided nipple, eases out. There are also generic and Alfa-specific pilot bushing pullers.
Discussion Starter #18
BTW, NAPA was the only store that said, "Yeah, this cutting die is NOT what you want." Good for them! So that's where I bought the plastigauge. I hope to check that out on the journals tomorrow. Probably worthy of a new post if I have questions. Thank you all!
1 - 18 of 18 Posts
