As part 2 of my question about replacing the "Inzione" badge on the plastic spoiler of my '88 veloce, I am wondering how it is attached? I can feel an adhesive, but is there also a small screw or bolt? That would then entail removing the spoiler to ge to it. Easily done, but I don't want to make more work for myself!
originally?
2 strips of adhesive and 2 pins with retainer clips
so don't just pull, or you'll take a chunk of spoiler with it
likee here:)
And removing the spoiler ain't that easy...it is both bolted and stuck on.
1987 Alfa Romeo Quadrifoglio
take a guitar string or thick fishing line and take it underneath the emblem. it'll eventually cut through the rubber.
Yeah, but the pins?
If I had the same problem here’s what i‘d do: i wouldn’t remove the spoiler as they never go back on as nicely.
I would buy a new badge so you know exactly where the pins are....Drill the old badge exactly there to separate badge from pins, remove badge and then snip pins off new badge and just stick it on
Unfortunately I am not replacing that badge. It is in fine shape. I am replacing it with the earlier model Alfa Romeo Script.
Any other ideas?
Any other ideas?
then you'll have to remove the spoiler
