The spare Bosch pump I have has a .31" outlet with the "expanded" nipple at the end at .34" (no rude comments from the peanut gallery please). A 8mm hose fits nicely. Don't want to belabor the obvious, but have you actually tried putting a 8mm hose on the end?
Nope, don't even have an 8mm hose yet
I did survey the situation a bit more though last night and
not to belabor anything
, the outlet I guess could be (with a caliper) .31" but with a ruler looks like .25" (I'll concede to it being .31") and the expanded ****** is just a bit (I guess .31") smaller than 8mm.
I noticed that a 5/16" line was run from the end of the Spica electric pump to the metal line. I will replace that with 8mm. The line on there is 18" long but since the Bosch replace will not allow a 90 degree turn, I'll get a 2 footer as a replacement. I also
noticed a slit in the (?) vapor line where it goes into the trunk. Never would have noticed it if I didn't pull it out a bit. That'll get replaced also.
RT - final questions.
1. On the line that comes out of the tank outlet to the filter inlet and the line that goes from the filter outlet to the fuel pump: mine has a braid on it. Without taking the lines off, do you know if the braid is part of the hose or can it be taken off and put on the new hose? and
2. the electrical connections - when I take the connections off the old pump, will I know how to connect them to the new pump as the new pump has 2 possibilities - one with small screw threads and the other with larger threads.
