My horns on my 79 are not working and I was digging thru my spares and came up with a horn with multiple terminals. My knowledge is with 79-86 spiders which only had one tab and one mounting stud on the horn. Both terminals look like they are isolated from ground. The one I found which I was told was from a 74 has the mounting stud and one stub with a tab and one with no tab. #35717 on a couple of spots made by FIAMM. Is it a two tone horn or is one of the connections for different tones/ ground connection?
Joe
Discussion Starter #2
I don't know if I have been cut off but I figure someone should of had a opinion by now with a simple horn question. Picture now attached.
Joe
If there is no continuity from either connect to the body of the horn they are simply the two contacts to the horn coil.
Ok I can deal with doing the junkyard mechanic way and just throw 12volts at it but was the horn used on ALFA's? Meetering it will not tell me if it was a ALFA horn and if it would be two tone L or R horn.
Joe
