Hi,
I'm having some issues with the horn and flasher-relay on my '75 Alfa GT Junior.
The flasher relay is the can-type with 3 pins (X,L,P). It is the only thing connected to fuse 3 (8A). Yet the fuse keeps blowing out, sometimes right after we insert it, sometimes it takes a couple of minutes (the indicators do work during these minutes...) I've disconnected the flasher-relay, but don't really know how to test it. I've put an ohm-meter between the pins L and X and measure about 25 Ohms (this should be the control-circuit). The other pins are open contacts.
Anyone know if that's an indication that the relay is bad? I would like to test the relay with a 12V source, but I think i'll just short it as there is no load connected to it (it's out of the car).
Also the horns stopped working, I have an original FIAM relay block in the engine-compartiment (3 pin), that runs a single cable to the horns, so I'm guessing that's the relay driving them. I tried to short the horn-button on the steering wheel by connecting the pin on the relay directly to the ground, but the relay doesn't click and the horns don't work. Anyone know if there's another way these can be tested? The horns work when directly connected to 12V.
Thx !
EDIT: Nevermind the horn-relay issue, it seems I don't have a solid 12V powersource connected to that relay.
Thx !
