This is odd ... I havn't seen anything like this yet in my search for cam timing.
Caution Long Story! Where to start?
Okay, first I was getting oil in the coolant, not emulsified, just drops of oil. So it makes me think I need to change the head gasket.
Then, the VVT connector falls off, hits the fan breaking it and itself. Unfortunatly this I didn't hear untill I got to work. So with the unbalenced fan flopping around the water pump started to make noise (bearings.)
Oh, to change the water pump. I removed the main pully - I used a 36mm socket, a breaker bar and the starter - Wedge the breaker bar on the ground, disable the ignition and fuel pumps and tap the starter. The nut comes right off and so did the pully. Oh, there is a cavity in the water pump that has oil in it, why? Could that be where the oil and coolant started mixing?
Now on to the cam timing marks. I also measured the lobe hight, it's about 11mm. The exaust is lined up with the proper timimg mark, it's about 10ish mm high. In the blurry photo you can see the punch mark someone added that the cam is lined up with.
Intake
Exaust
The water pump
While I was there I Painted the main pully, I also painted the timing marks.
What did they do? What should I do?
Thank you!
Intake
Exaust
The water pump
Thank you!
