1 - 13 of 13 Posts
I've been cleaning out the barn in preparation for a move and found the following object in a box that had some Alfa parts. While it may have nothing to do with Alfa, I thought I'd post it in case someone recognizes it and can tell me what it does.
~jim
It looks like a tool used to hold a toothed pulley and keep it from rotating, a much smaller version of the tool used to grab a flywheel tooth and keep it from turning. It was made to fit two different diameters of pulley. Nothing that I recognize from messing with early (pre '75) Alfas but maybe for the cam pulleys on a V6?
Push hard and live
Called a "spanner" and as noted, use to grip externally-toothed nuts. Commonly used on various aircraft components. Might fit the rear axle bearing retaining nut on an Alfa.
It's a pin wrench. Various tools use this to hold the shaft so that disks or bits can be changed.
Not an Alfa tool.
is there a prize for this?:):) question, could you flip it over, might be writing on it
Discussion Starter · #10 ·
Alas, there is nothing printed on the opposite side. But, given some of the creative answers I received I should have offered a prize. Then again, given all the diverse answers, it's obvious this little gem needs to be placed alongside the duct tape, hammer, and vise-grip in my toolbox for Alfa emergencies.
Thanks for all the responses, but I need Tifosi to translate FN FAL...
~jim
1 - 13 of 13 Posts
