I would take the small terminal wire off sender by front timing belt cover, clean terminal and blade pin on sender and try again. Also remove black groiund wire bolt from mid housing and clean that grounding point.This morning after starting for the 1s time, the high temp light came on and didn't go off until the key was turned off. The engine heated up normally and didn't over heat. Is there a solution beside removing the bulb![]()
