well here i am again.... after replacing my starter and waterpump i found a new problem. its this grind i hear everytime i drive my alfa it hapens any time rpms are over 3000 although i can find places were if i put just enough throtle i wont hear it also if i am in neutral really have no clue what it is. my friend sort of stole my jack and stands so i havent had a chance to go under yet. i am planning on changing my trasmission oil to see if i find any signs of shrap metal or shavings im going to put some red line 75w 90 ns on it to see if it makes a difference. well the clutch feels great and none of the gears have any probs they all go in smoothly no prob only some grind when i shift into reverse too fast but that rarely happens. the tach is also dead but i dont really use it anymore. and the engine is extreamely healthy will not lie but it is a runner and likes to be pushed especially here in san mateo on the 280 on the extreame down hills i have honestly reached 105mph with out problems.... though i think i was probly about to red line because when my tach did work 80-85 mph would be around 4600-rpm
heres a vid i took on the grind
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/X7mKdNB54Gw&rel=1"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/X7mKdNB54Gw&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
