Help with water pump
682 Views 2 Replies 2 Participants Last post by  patyz
Hello, I am inthe process of replacing the water pump on my 78 spider, all hoses ,radiator, fan and nuts on the pump are removed ( exept the ones holding the tach drive). do these bolts need to come off? Because the one against the block is giving me a real hard time. what can I do to free up the pump from the motor? it does not want to free up.
thanks alot, Pat
Here are some threads the search function found - (these are links you can click on).
problem removing water pump
water pump question
