1 - 17 of 17 Posts
Could someone please photograph a close up shot of the under-hood I.D. plate? I need to see size of punched letters and numbers and spacing of the I.D. info. etc.
George
Discussion Starter #2
Please... someone must have the ID plate and could take a photo for me
Pleasessssssss ;)
I kind of hate to ask Bill again. I have asked his advice soo many times before. All I need is a close-up photo! Anyone?
G
Is this what you are after - the original one from my 1960 spider Normale. Scale is in cm.
Thanks for the photo but that is not the one I need. Actually, I forgot about that one. There are two other, larger plates mounted to the underside of the hood. One is the lubrication chart (don't need a photo of that one) and the other has the motor and body numbers and Giulietta model. That's the one I need a photo of. Do you have that plate?
Great photo by the way. ;)
G
Perfect. Thank you.
George
You can tell how careful they were at the factory in those days! ;^)
Yah, great workmanship. One further question. I have a 1960 1300, 101 Veloce. Do you think I would stamp 101 F where you have 750 E?
Cheers
That sounds right. My plate is from a '57 Sprint Veloce.
I'm by no means a Giulietta expert but I'd say no. The letter designations ID'd a particular model within the 750 Series; E=Sprint Veloce, F=Spider Veloce, etc. With the change to the five digit model designation format, the first three digits represent the chassis series while the 4th & 5th digits represent the particular model.
Having said that, your Giulietta is a 101 Series and the Spider Veloce was assigned 07 as the model. Therefore, I'd say that the plate should be stamped 10107.
I agree with Jim.
Discussion Starter #14
That would make sense as my other small plate (mounted to the firewall) is listed as 10107 as well. Do I need to stamp anything in the kg spot? I see the sample above is empty there. Thanks for the great help.
Cheers,
G
'60 Spider Data plate
Hi George
This is the plate off my '60 Spider - sorry the picture is fuzzy, it was taken 5 years ago before I bought the car & the PO & I were deep into the 3rd bottle of wine during negotiations - I recall the picture was crystal clear at the time....... :D
I agree with Jim, your plate would say 10107 - I'd suggest that you got hold of Andrew Watry, (post #2) as his Veloce is the closest to yours & got a couple of pictures of his data plate.
101 / 105 Guy - that data plate is from a '58 Sprint Veloce Confortevole - do you have any further info on the car - PM me please
Ciao
Greig
Discussion Starter #17
So as my car wasn't an export, what would I stamp in that space?
G
1 - 17 of 17 Posts
