1 - 11 of 11 Posts
i have a 1977 spider 2.0 i recently got it running but i found out the tach cable is not hooked up to the engine. does anyone know where to attach it?
Waterpump on driver side. If you still have air pump look under bracket and between top alt.
Right under that nut/stud that hold Alt. bracket And behind crank pully
i still cant find it did alfa use electronic tach in their 2 liter engines at any time? there is just bare metel in the spot it should be.
thanks for the great pictures but on my engine there is just bare metal where there should be the tach hookup. any ideas?
you may have water pump from newer model
i have 85 and have electronic tachometer, with signal wire from ignition coil.
transmission port in my alfa is for a speedometer
The 73-79 Spider parts book says that up to 1977, the tachs were mechanical; 77 and up are electronic. However, an electronic tach doesn't show up in the wiring diagrams until 1979.
Does the face of the tach say 'Electronic' on it somewhere?
i don't see electronic anywhere on it. but the tachometer cable thats still there is mechanical.
can you send of picture of where the tach cable comes out of the coil on your '85 spider.
its just attached to (as far as i remember) since my vehicle is in parts right now, to a negative terminal of ignition coil, rest of wiring wal just positive and illumination.
1 - 11 of 11 Posts
