1 - 10 of 10 Posts
Many say yes, some say no. I figure it depends on how many miles are on the unit on the car. Carlo, my Alfa specialist, says that he's not seen one fail hydraulically, but he has seen a couple where water collected in the open top and rusted the shaft/piston, making it stick (maybe that area should be filled with grease or Vaseline?). Those he changes, or whenever the owner wants it changed anyway.
For my LS with 110k miles on it, 10k on the new timing belt, I will probably change it the next time the belt is changed, at about 140k miles or 5-6 years, whichever comes first, just because.... I don't know if it was changed when the belt was changed at the 60k miles major service when I bought the car in 2004, but I very strongly suspect it was. Will have to review the service invoice from Carlo. It wasn't changed when he changed the belt 10k miles ago.
Others may recommend a different schedule. I say go with the majority.
Don't know anything about that. Not sure one could duplicate the precision of the manufacturer.
No that's a kit for the 12V hydraulic unit. I agree with Del except I have seen many fail since I have sold many for failed units. I have sold around 12-15 units this year alone so that should tell you something. Age/mileage is the main failure of these. They last around 100K miles, some less, some more.
Per my email last night, as soon as they come in let me know and the whole purchase will be made.
I got it all yes.
Tensioner is $395.00 (more in this next week) I am trying to keep the price down on these but they may go up soon. Not sure yet. Not by much though.
Timing Kit # 1- 164 24V + Aux Belt Kit-(Belts/Idlers/Damper/Timing&Aux Belt bearings)
24VTK1
US $844.00
This is all in stock:
Qty part number nomeclature
1 60618584 belt, serpentine for accessories
1 60561380 tensioner, serpentine belt
1 60810660 idler pulley, Timing Belt alt p/n 60561649
2 60561615 idler pulley,serpentine
1 60561614 pulley, serp tensioner
6 60513838 plug well gasket
1 60561244 timing belt
2 60810644 TB idler bearing alt p/n 60580235
1 60584475 TB tensioner No longer available new test old one
1 60568809 VC gasket L/H
1 60568808 VC gasket R/H
4 60513833 gasket, front cam cap use sealant if bad or missing
1 71720318 gasket maker for 60513833
1 60810715 water pump 24v 60559314
1 60811792 gasket, wp 60615714 preferred steel gasket
1 60559862 thermostat
3 15248711 Bolt, thermostat M7x1.00x55
1 60507415 gasket upper
1 60507416 gasket middle
1 60615716 gasket lower 60615713 preferred steel one
1 60573501 hose, right to head
1 60573502 hose, left to head
2 14458680 oring WP tube mid housing water pipe
6 60576441 seal intake chrome tube black rubber ones
6 60513868 gasket, int chrome tube
1 - 10 of 10 Posts
