Hello,
I have a few questions related to the clutch slave cylinder:
1)Is possible to buy it separately AR p/n 105.48.12.050.03/14? Is possible where can I get one?
2)The catalog do not list one, but can I get one that is longer?
Last year when I had some clutch work done (including a new slave cylinder) looks like the "experienced mechanic" replaced the push rod, doesn't look nothing like the one in the catalog.
The one on my car looks homemade and is 2.5 inches long (both ends are bullet shaped).
At the moment the slave cyl. works but the there is no enough piston travel (the release bearing and fork are good). Is there any way to adjust it?
Thank you for the help.
You might try Jon Norman's Alfa parts; he might stock them separate from the whole cylinder. If you still need one, I have some used ones lying around and could come up with one.
