I have tried the usual, and not so usual sources.. Looking for the rubber grommet that the throttle cable passes through its mounting bracket, at the throttle body. I have 2, both are in pieces. Anyone use a suitable substitute ? Thanks.
In for an answer, too.
I did read somewhere that someone found a part in either the electrical or plumbing section at Home Depot that worked almost perfectly. I'll see if the deep search turns up anything.
Discussion Starter · #5 ·
Thanks for that , but that's not what I am looking for. My car is a GTV6, and that looks to be the grommet that comes through the firewall.
Discussion Starter · #6 ·
Discussion Starter · #8 ·
Update...
After taking it for a drive, I noticed my idle was higher than before. The cable was so loose in the bracket before, now its holding the throttle open a bit. Will have to loosen up the cable a little.
