FRB 11 parts and solutions
This is my second attempt to answer you. Somehow I erased my whole commentary on your problem
. The problem is not unusual. The Fispa FRB 11 regulator is an excellent unit used both by Alfa and Ferrari with Webers. It has two purposes. First to keep fuel pressure about 3 lbs. and second to reduce the pulse hammering effect to the needle and float by either mechanical or electric fuel pumps. The leaking failure is either from the diaphragm, or the upper bowl seal. These are prone to damage from additives in current fuels. Fortunately, there is also a REAL solution as well. Goeffery Ohland, Partsource, 207-236-9791 has NEW neoprene replacement diaphragm's and bowl seals for the FRB 11. Tell him I sent you. I have used his parts in my small collection of regulators I cycle between cars as they develop leaks. His parts SOLVE the problem.
If your car is on a level surface, with the battery disconnected, your fuel flow WILL (eventually) stop. It is caused by pressurizing the system with the pump. No pump, no pressure. Remove your FRB 11, carefully disassemble, (Don't loose spring & ball in the top) Do not fiddle with the adjustment screw. If it was set correctly before the leak, it's still OK. Clean the whole assembly, while apart, replace the diaphragm and bowl seal (and filter if you bought one from Goeff). Check the top surface of the body to be sure it's FLAT. Over tightening the top screws can distort the top. On reassembly, tighten these screws evenly, enough only to seal the diaphragm. Over tightening will warp the top. Back together, reinstalled in the car, leaks are gone for good
. If you need more help, let me know.
Gordon Raymond
