Ok I am trying to remove the plenum. I have removed everything the shopmanual says, except the brace from the engine mount. I cannot find the bolts that hold it. I can feel a 17 mm bolt on the bottom side of the plenum, I started to remove it and fuel came from the hole. Is this right. Please help, where are the bolts?
Also I noticed the motor mount is oval shaped, is this an after market mount.
