so i just pulled the intake manafold and a bunch of oil drained out im guessing that is not good. can anyone help me out should there be any oil in there i am charging my camera now to take pictures thanks
Your oil separator is clogged up. It's supposed to use intake vacuum to create a vortex in the can through which crankcase fumes are vented. The heavy oil gets slung out to the sides and drains down the small tube back to the sump near the dipstick. Check that tube first to make sure it's not kinked or clogged. If it is the oil backs up in the separator and then gets sucked into the intake either through the big tube that goes to the airbox or the fifth idle intake hose off of the idle air manifold.
Looks to me like the cam cover or the breather tube on the cam cover had a leak.
The oil ran down and collected on the shelf above the ports.
hey thanks i was thinking the ovp because mine is was bad i have been getting hard chunks of rust im thinking it might be shot
