I can't get my signal lights to come on when I switch the lever
They will come on when the headlight switch is turned but no blinking
What I did:
1.Took the steering wheel and combo switch off
2.Took the signal light switch apart
3.I repaired my broken signal light switch lever.
4.Took notes.
5.Put the Combo switch on the column.
Symptoms:
What works:
1.Headlights dim and bright
2.Parking lights
3.Warning lights
4.Wipers
5.Flasher worked fine before repair of switch lever
6. #5 fuse is good
What doesn't work
1.No signal lights at all when parking lights and headlights are off when I click the switch up or down.
2.When the Parking lights/headlight switch is turned on the Signal lights come on (down switch = left signal lights come on but no blinking, up switch = right signal lights come on but no blinking.
Please look at the attached photos to see if I connected the 3 single wires (Black, Yellow, and Red) from the left side of the combo switch.
What am I missing? Any help would be appreciated. Thanks!
What I did:
4.Took notes.
Symptoms:
What works:
2.Parking lights
3.Warning lights
4.Wipers
6. #5 fuse is good
What doesn't work
