Hello, I am looking for any advice to remove the side exterior door and body trim. I have already removed the lower skirt but dont know where to start on the molding. Is this glued on or is there tabs?
These are tabs. If you remove the panels behind each stirp you will be able to compress the "tab" with some pliers and push it through the panel. If you try and pull it out you will damage some of them and bend some of the trim pieces.
