Hi all, I am just finishing up on a 2liter liner/piston change. I pulled the engine and tore it down for the change and now with the engine back in the car, I have a hardened bolt left over. It has a 14mm head, fine thread, 30mm long with a slight sholder at the head, and approximately 10mm diameter. I have no idea where it might go. The engine is a 77 spica spider engine. The bolt was in the can with the upper and lower oil pan bolts, as well as the drive shaft joint bolts. I know its not the right size for the oil pump bolts, any pan bolts, flywheel, clutch, or trany. Any ideas.
John R
John R
