Hi All,
I'm installing a 3.0L engine into my 1985 GTV6 and hoping to tap into this excellent forum's expertise again as I work through the issues. From what I've read this should be pretty much plug and play with the existing ECU, but I do have some things to do before I can drop in the engine. It has to pass CA smog checks, which I heard is not a problem with the 3.0 L and original 2.5 ECU.
A little history of this....I bought the '85 GTV6 back in 2011 in Dallas and drove it home. The car has some surface rust underneath but the body is solid with a fair respray. Although it seemed to pull strong when I test drove it, when I got it home I noticed a clattering sound when it was warmed up. It didn't sound like rod knock but I guess it was on its way there - every experienced mechanic suggested looking at the bearings. This looked like a good learning opportunity, so I pulled the engine and took it apart. I found the bearings and the crank were really worn out (not to mention the flex discs and drive shaft center bearing), so it was a good call to stop driving it.
A little background on the engine...I bought in September from Larry Sr. at APE. He said that it came from a Milano that was totalled back in 1989 with only around 14K miles. The engine supposedly sat in someone's living room for the next 20 years or so and in the mean time the owner had died (maybe someone here knows the original owner?). His widow eventually sold it to Larry. When I saw it I noticed that it really did look like a practically new engine. It turned freely and didn't seem damaged, so I took a chance and bought it. Larry was upfront about everything and I enjoyed dealing with him.
Here is what I'm planning to do in this project - I've got questions about a lot of this stuff since I'm a novice wrencher and I appreciate any and all thoughts:
1. Inspect and adjust valve clearances
- torque down the heads??
- replace valve cover gaskets (they look new!)?
2. Convert detensioner to mechanical type using this procedure
3. Replace detnsioner, timing belt, and water pump using the ones recently installed in my GTV6 engine (less than 2 thousand miles on those parts).
4. Remove injectors and send them to Hi Performance store for checking and cleaning
5. Replace all hoses to silicone type from Hi Performance store
6. Replace motor mounts (side ones are done). Rear one looks new, but should I replace it?
7. Move the throttle around the 3.0L intake plennum to match GTV6 layout
8. Use POR15 on the driveshaft and replace flex discs
9. Use POR15 in the engine compartment since there are some rusty places
10. Send radiator to be inspected and rodded
11. Look into replacing electric fans with SPALs
12. Clean gas tank? Gas sat in there a few years before I added Seafoam.
13. Keep or toss out non-op AC?
14. Upgrade headlight wiring with relays
15. Control arm refurbishing (has surface rust)?
- seems easier to do with engine out, but not an easy job for a novice
16. Replace rusty castellated nut on steering rack
17. Drop out entire rear suspension to refresh tired DeDion parts, remove rust, and replace shift bushings.
- inspect clutch at this time too
- inspect and replace rear brakes while its easy.
- replace rear tranny mount
18. Replace exhaust headers with 3.0 L style
Anything else I should do while the engine is out?
I plan to go through the list on this post and show progress plus ask a bunch of dumb questions along the way. If you guys know of some useful threads related to this, please let me know. I've done some searching and reading but might've missed some.
Thanks!
Thanks!
