what part?
i have noticed that the brake master cly. gets very hot during a drive.:eek:.the clutch master must get hot also...i mes. it at 180-240 degrees..this cannot be good for it.:(.have any of you made a heatsheild to you car at that point?..i am going to make a cardboad templet this weekend..pro. out of sheet alum.
1966-2013
S3's should have the cast lugs but no machine work done to them though.
I know for sure msiert's has the lugs with no machining or shield, ('91 S4) and this photo shared by Green Dragon from a shop he was at certainly shows the lugs clearly enough on as far back as '68 or '69.
T'would be simple enough to drill and tap the bosses then put the studs in for an S4 shield or custom fabbed one.
