my 1988 Spider is leaking, my heater core is rusted .Does anyone know where to start?.....I bought a new one, how can i do it by myself? I will apreciate any advice
Hi moty30. While some people on this board are savvy enough to do this job wothout the removal of the dashboard, I have been not so fotunate in such a task. Howeve, I will say that it really is not as hard as you may think.
You can get an idea of what is intailed here:
http://www.alfabb.com/bb/forums/car-restoration/3922-heater-box-rebuild.html
The folks on this board are pretty knowledgable and willling to help, so I'm sure advice will be coming.
Galliano
Your Spider was assembled around the heater core... You take the whole car apart until all that's left is the heater core!
Well, almost - remove the center console & the dash. Then you will have access to the heater unit. It is not as daunting as that sounds - you'll spend most of the time removing the center console. Then disconnect the main instrument panel & four bolts to remove the dash. Take lots of photos. That'll help you remember how to reassemble everything plus you can post them here - we likes photos.
Eric is right. Also, maybe write down step by step, each step so after you mount all beck together, you will just do it backwards. Use little ketchup paper holders and number them. Place screws inside as per step done. This will save you much time screwing up the screws in the wrongly sized holes. I did this 2 times, and hope not to do again EVER.
Certified Oldschooler
Your Spider was assembled around the heater core... You take the whole car apart until all that's left is the heater core!.
LOL +99 :D:D, this is how I felt on an S1 and I could not imagine it on an S2 or after.
whomever invented consoled should be disgraced. Only purpose they serve is for cup holders and such....
and "a look"
