When I got my '91 Spider nearly 20 years ago the trailing arm bushings were worn out. My mechanic at the time replaced them with polyurethane in front and HD rubber in the rear of the arm, saying that the stiffer bushings gave better handling.
A few months ago it was time to replace them again, and following some of the advice on the BB I just went with the standard rubber given that the suspension is otherwise basically stock. After the change I started having issues with the car feeling super shaky on any sort of uneven pavement. Like, it was bad enough that I had to check a few times to make sure nothing had gone wrong with my chassis stiffener or the suspension torquing. Just a lot of shake and instability versus what it was before, especially in mid-corner bumps.
This weekend I pulled the stock bushings and installed the HD ones from Classic Alfa. Night and day: the car feels tight again and the shakiness is gone.
Car has stock springs, Koni red shocks set to full soft, and poly cone bushings and flat washers in the trunnion. Based on this result my recommendation is to go with the HD or poly trailing arm bushings as they really seem to tighten up the car.
