First the issue. Initially, 101-1600 era and earlier, there were no connectors between head and block, and this was often the result.
Racing TransAm GTA's we made connectors of aluminum that looked much like Norman's.
Often the "O" rings were blown up into the head plugging cam oil feed holes. This resulted in "blue" cam journals ("Oh! That one got hot!") and damaged heads so we made up connectors to support the "O" rings.
The positive side effect was no more oil leaks between head and block through the head gasket.
This is a kit. It's cheap and works perfectly with Reinz and other head gaskets. With some blocks, the hole in the block deck is a trifle tight, usually 1300's, 101 and 750's, 105's and newer are more uniform, but regardless, we made up a drift to correctly install the connectors in tight deck holes.
The inside diameter of the hole exactly matches the OD of the connector small end, and is drilled so the end of the connector is supported on the walls, end and flange.
They can be gently tapped into tight galleries with this aluminum drift until the flange contacts the deck. Then the head gasket is installed and "O" rings over the connectors in the pocket in the head gasket.
Head is installed normally and torqued. Completed the "O" ring is fully supported, outside by the gasket, inside by the connector, and compresses for an oil tight connection.
These are re-useable but I keep spares to replace any damaged. This is cheap insurance, and superior to either split pins or roll pins.
