Trying to button up and turn over/run my 84 2.0. Actually all buttoned up, but turning not so much. I filled it with new oil and filter and was going to bump it over to circulate the new and start cleaning out the remains of a good head gasket failure. I currently have no power to the ignition switch or gauges etc. All electrical worked fine when I started in on the head work. I'm thinking there is something I undid that I have missed on the reassembly.
I believe the only power connections I undid were the battery, alternator and starter, all of which I reconnected. Turn on key and nothing. The battery is fully charged and worked fine a few months ago. All fuses under dash I can see are good. Haven't checked the relays yet.
I have 12V indicated between battery + and nearby body ground. I do not have 12V between the Alt+ wire to the battery and nearby grounding surfaces. If I round up a friend I can check continuity between the under hood "power block" on the drivers fender and the battery lead.
Any BTDT's welcome. Once I get this turning happy to have opinions on best way to rid engine of oil/coolant/water mix.
