Did a search, but no one describes how the finally fixed it.
Conditions;
All conditions- hazards work as they should
ignition on, no lights on- blinkers do not work at all
ignition on and parking or headlights on- blinkers work, but are steady ie no flash
I cleaned the fuse panel and replaced all fuses, and looked at the soldier inside the flasher relay on the fuse pannel. Is there a seperate flasher for the blinkers only?
BTW...I get no power to the turn signal switch when the lights are off.
Conditions;
