I have a 79 spider with a console that do not match with 79 or 80.only have the DEF and hazard, anyway I got the hazard switch from IP, but in the back there is about 5plugs. I try all of them but neither work, my problem is that the signal lights do not work, neither of them ,I check ground etc. I believe that is possible that because the hazard is not connected, the other ones do not work.
number 6 fuse keep blowing, maybe the reason, if somebody know how to connect to the switch?
The switch have 5plugs and numbers from 1 to 8. if someone know how to plug them? I cant use the car because without signals I wont be able to pass inspection.
