Hello All,
This is my first post. Thanks for understanding as I ramble. I have a pretty decent Alfa. It's been pretty much trouble free for the 8 years I've had it. I don't drive it much, Just mainly in the Summer. I took it for a drive the other day and it started sputtering. I thought injectors, It turned out to be slight arching in the coil wire that was rubbing against a bracket. I taped up the wire and drove it, ran perfectly. I need new wires. The other day, I started it up and drove to the gas station, as I was driving, I noticed my oil pressure was just one notch above zero, and zero at idle. . I got gas, and called the tow truck to bring me home to be on the safe side. Usually ,the oil pressure reads just below 57. I happened to look at the gauge and it was very low. So today, I went to turn the key to put the windows up, I had no power to anything, but I could start it. I just cranked it quickly and shut it right off . With the car off, I just noticed my temp gauge reads .like the car is on ! I just had turned my fuses around in the box to see if anything had blown; nothing was. I wonder if doing that could have caused me to have no power in my dash or to be able to shut the windows ?
I guess the first thing I want to do is check the oil pump. Is there a way to manually check the oil pump ? I need to buy a service manual.
Thank you
Thank you
