1 - 1 of 1 Posts
Has anyone swapped the pinion on a starter motor from 9 tooth to an 8 tooth pinion?
I want to run a 3 bolt 75 TS starter on a 1600 bellhousing instead of the original 2 bolt starter, the car has a 2L flywheel which is being machined down to fit a 105T ringgear so i can fit it into the 1600 bellhousng (TS conversion on a cable clutch car).
The shaft that the pinion spins on is identical in size between the 1600 and 75 starters, is it possible to swap the pinion over from the 1600 starter to the 75 TS starter?
Cheers!
1 - 1 of 1 Posts
