Hand throttle not holding
1238 Views 4 Replies 4 Participants Last post by  mmataija
Hi guys,
I have a Euro-spec Spider Junior from 1972, which has the same dash arrangement as the roundtail. Below the dash there are levers for choke and the hand throttle. The hand throttle is correctly connected, with little bracket connected to the brake servo which holds the outer sleeve of the hand throttle cable.
The issue is that the spring which is returning the throttle pedal to upright position seems to be too strong for the hand throttle arrangement. In other words, when I pull and hold the hand throttle lever - it engages the throttle. When I let it to, the car returns to idle immediately.
Does anybody have an idea on where the problem might be?
Thanks and regards from Croatia,
Marko
1 - 5 of 5 Posts
If it's like the later cars, you need to pull then twist the knob to lock it.
-Jason
Kinda like the chute adjuster lock on the handlebars of a snowblower, or the throttle lock on a older vintage military truck then?
Cool.
If memory serves, the lever pivot screw is also the friction adjustment. Lowering the levers assembly from the dash will reveal this screw which can then be tightened to increase the friction.
Thanks, Papajam! You were right as usual.
I just tightened the screw and now everything works perfectly! :)
Cheers from Croatia,
Marko
1 - 5 of 5 Posts
