I was installing my new to me BWA's on my 78 spider tonight. When I jacked up the FRONT drivers side I found this.
Then I went to jack up the FRONT passenger side and found this... scraped, gouged metal... What went wrong?
When I asked him "why" this was his reply...I had to cut off the top/protruding threaded rod as it was hitting there...
Glad I caught it before it went nuts there...after shock install there was ~
1/4" gap which turned out to be not enough so I cut off all of the exposed
threaded rod in case in addition to rubber bushings compressing & moving
around IF the body metal was flexing the rod would no longer hit there...Maybe your car is tweaked...I don't think so...A bit of creative work to get
the shocks to fit & I would not stress over this...you can red rattle can or
undercoat this area or I can put some wurth rust gard on there in silver or
black...up to you...
I don't know why both sides are different on your car...the old shocks I
removed I think had different lengths of threaded rod on them which I guess
is why I needed to do this to the koni...however I removed a different brand
then the koni's I put on...
