Word of advice about the in-tank round baffle surrounding the pick up tube and screen that bit me: The coating inside the tank probably filled in okay internally for mine, covering most of what it was supposed to, but it also filled in the flat rectangular holes at the bottom of that round baffle. The sealer acted like a dam around it, not letting any gas get to the filter screen. I had to open the tank's cover for the tank sending unit, pulling the sender out for a peek. This was a troubleshooting effort after putting two gallons of gas in and not getting any down the line to my filter for my first engine start, even after compressing a little air to the tank to push it. Sure enough, the in-tank filter screen area was dry as a bone inside that baffle.
I'm siphoning out the gas this weekend, then picking through the bottom of that baffle to open it up. Unless your tank cleaning guys blew out the line and that area AFTER the coating, you may have the same problem. Check it out, its easier to check when off the car. Maybe use alcohol or something that evaporates to see if it gets to the screen.
