1985 Alfa Romeo GTV6
Ok, so here's the situation.
My GTV6 came with a modern headunit and modern speakers. The wiring job was an absolute nightmare-- butt crimps on butt crimps, no wire colors matched, stuff spliced into other stuff, etc. So I decided to clean it all up and put in a stock radio.
I bought an Audiovox AV-954 on eBay and it works (I bench tested it), but it only has 9 outputs from the wiring harness:
  • 12v+
  • ground
  • "clock lead"
  • right front speaker +
  • left front speaker +
  • front speaker -
  • rear front speaker +
  • rear speaker -
Obviously, it is designed for a front common ground and a rear common ground, which doesn't work with modern speakers. It came with Polk db525s in the front (5.25", coaxial, 45 watt RMS, 135 watts peak, 4 ohms), and Pyle Blue Label PL463BLs in the rear (4"x6" 3-way speaker, 240 watts, 4ohms).
This leads to a few questions:
1) I just ordered a cardisk to get the actual wiring diagram, but it would appear that the ground and 12v come off the harness that attaches to the power side mirror cable/switch, but where do you draw ignition from?
2) What is a "clock lead", and where should I hook it up? Is this actually the ignition lead? I've only seen setups with yellow (12v+), red (ignition), and black (ground).
3) Because the headunit uses two common grounds, I thought about using a floating ground adapter, but fga's are all setup with the 8 inputs (from a modern headunit) as the input, with the 5 wires as the output. Can this run in reverse, and how can I wire this for the TWO common grounds instead of one?
4) I cannot find an impedance rating for the headunit. I'm assuming that it can handle 4-8 ohms and won't fry anything, but how can I check?
5) Would this type of 1980s headunit be able to power those speakers, or do I need add an amp into the equation. I just want to get the thing working; I'm mainly listening to the engine, but it would be fun to play cassettes in there occasionally.
Any help on this would be really appreciated.
1986 Alfa Romeo GTV6
Completely different approach here.
Buy the alfa romeo cover that covers the radio slot.
Buy a jbl portable bluetooth speaker and connect it to your phone.
That's what i was going to do, but then i found someone that actually knew how to connect mine.
I know nothing about the car electrics, but a car audio needs power and ground. Antena and speakers. that's it!
Here's some good info.
But me personally wouldn't touch any of it.
No, actually- I like your idea of keeping the original cover! I might try to find one of those. And the article was helpful for an electrical noob like me😸
These are way cheaper than when i bought them and you'd be amazed at the sound.
I got the JBL charge3 good but not enough.
