The difference on the two GTV6 styles...
The earlier design has the break line between the two shell halves going thru the exact center of the ignition key hole. The hole is a perfect circle. This uses a round bezel around the key.
The later update, has an egg-shaped hole at the key hole, and an egg-shaped bezel around the key. Most of the key opening, in this design, happens in the upper shell. Maybe 1/4-1/3 of the hole is in the lower half.
If that does not make it clear enough... e-mail me, and I can send pix to show more clearly. If the earlier responders can't help, I may have one of each as spares.
Peter
[email protected]
mine is round key part number 116 46 23 102 00. My screw sleeves are all torn up thus needing a new one. I will contact you if the other party doesn't have it.
Just so you know... I have the upper and lower halves for the later design. But only the upper for the earlier design with the circular hole. Sold the portion you need a couple of weeks ago.
Just to let you know to keep your options open with the others.
Peter
