You could try a piece of welding wire or similar to use as a retainer. not to tight it would need to be able move to let the adjuster rotate
Has the adjuster undone itself from the piston you may need to put slight pressure on the piston to allow the adjuster thread to take up' keep slight pressure up until the piston starts to retract. that's the only thing I can think of
