I am clearing out the garage a bit in anticipation of the return of my GTV6 body from the shop. These are all parts collected over the years to keep it running. I still have enough to keep things going, but need the space. Most parts from 85 GTV6 unless otherwise noted. Decent used condition.
E-mail me at [email protected]
updated 05/16/11
2 sets (LH / RH) cast exhaust manifolds – need studs replaced - $10/set
Starter - $40
Alternator – no regulator - $10- sold
Fuel injection manifold w/ injectors, cold start and regulator (works good) - $50 - sold
(6) 2.5 intake runners, rubber connectors and Roma Blok clamps - $30/set
Complete 2.5 heads w/ cams, etc - $75 - sold
Valve covers - $25/set - sold
2.5 cam set - $30 - sold
Left and Right timing belt covers – some cracks around plug wire clips - $20/set
RH timing belt cover – trimmed below tensioner - $10
Distributor w/ cap, rotor, water shield and rubber cover - $50 - sold
Thermostat housing – complete with thermostat and sensors - $30 - sold
Oil pressure style timing belt tensioner – needs rebuilt - $20 - sold
164 style mechanical timing belt tensioner – good used - $25
Upper and lower oil pan – decent shape - $40
Oil pump – used, but decent pressure - $30 - sold
Short block – crank, rods, pistons, liners, flywheel, front cover, pulley, engine mounts, bell housing - $50
Used (good) water pump - $10
Throttle position switch, late integrated style - $10
6 fuel injectors and cold start valve - $10 for all sold
(2) Auxiliary air valves - $10 ea
Gage style oil pressure sender – unknown condition - $5 - sold
1 set bare 2.5 heads – good for sectioning, porting practice? - $20/set
Head components – exhaust push rods, rockers, tappets, springs, cam gears, oil pump drive – let me know what you need w/ and offer.
(12) Intake valve seals – new - $5 - sold
Transmission – out of 85 GTV6. 4.10 final drive. Good running condition. Mild 2nd syncro wear. Will part it out. Let me know what you need w/ an offer. Dogs, gears, forks, bearings? sold
Transmission – Verde. In pieces. 3.?? Final drive ring and pinion. Dogs, gears, forks, bearings. No LSD (I’m using that in my transmission – sorry) sold
Early speedometer pick up (gear drive) - $30 - sold
Late speedometer pick up (Hall Effect) - $30
ECU - $30
Air box w/ K&N filter and AFM - $50 - sold
Flexible intake hose - $20
Air intake duct (from behind headlight to air box) - $5
Complete ignition harness w/ ignition module - $30
Complete Bosch engine harness - $50
Coil / ignition module / bracket - $15
Clutch master cylinder (probably need rebuild) - $5
Brake master cylinder (needs rebuild) - $5
Front driveshaft pinch yoke w/ guibo (fair, some minor cracks in rubber – good emergency spare) - $10
Flywheel sheet metal cover - $5
Exhaust hanger @ rear of bell housing – $5
Spica font shocks – OK condition - $20/set
Front turn signal housings (I’ll throw in a LH lens, but it is rough) - $10
NOS Milano front turn signal set – in bumper – housings and lenses - $35
Cowl vent block off plates for Tropic Air car - $5 for set (4pieces)
Rear defrost switch and seat belt light - $5 for both
Set windshield squirters (mount in hood) - $2 - sold
updated 05/16/11
Starter - $40
ECU - $30
